meanchicken
gallo vicioso
- Oct 6, 2007
Meanchicken, i appreciate what you are telling me but you stated that it is going to cost me about 6k to rebuild the motor in this car, but I can go to one of the vendors on this site and grab up a long block that is capable of like 400 hp or something and pay I think it was around 3500.00. That is a far cry from your 6k. The builder stated that he had a lot of experience with TR and would warr it for 90 days. Not long but that is what he said. I am doing my research. And thanks again but your numbers are a little off. I will continue to look.
Don't blow it off just yet....you need to consider what is included in that "just under $6K ($5800) tag.
The price I qouted is for a complete drop in turn key mild street engine (400HP plus)...better than stock (improved bottom end...), better head gaskets, mild cam, etc. set up perfectly...removed and installed by a guy who has been building these engines for 21+ years and made these cars go 8 seconds.
If you do the R&R yourself, you safe about $1K so ...now you're just under $5K.
Do some of the top end assembly yourself....you save a few hundred more....
getting closer to your magic number....
Re-use the intake, injectors, throttle body, water pump, etc.....you save a few hundred more.....we're not far off at all now.
Can you get one cheaper...sure....just saying....if you want to do it right ONCE....then you might want to pay a little more...ONCE...
Personally...I like to do it once and be done with it. Much cheaper in the end.
