I am looking at purchasing the valve springs for my 87 T. I was browsing the summit racing online catalog and came across two options for springs CCA-980-16 or CCA-980-12.
The CCA-980-16 info - Single spring, 1.230 in. outer diameter with damper.888 in. inside diameter, 322 spring rate, valve springs
The CCA-980-12 info - 1.230 in. O.D., .876 in. I.D., 308 lb. spring rate, single, valve spring set
I'm assuming CCA-980-16 but just want to make sure, thanks!
Dannyo
Dannyo
