I guess that's what it is.
Not sure how it would even work though, as it looks like it gets it's input from the compressor but doesn't have an out to the solenoid or the wastegate?
by bleeding off the boost. it wont try to open the WG. and you will get higher boost. you can control the boost by opening the valve. the more you open it----- the higher the boost will be.
