The problem I see with this , is the alternator is regulating its voltage output based on what it's "seeing" somewhere down stream in the harness after many questionable 30yr old connections . The voltage you need to "see" is at the output of the hot wire relay to the pumps & or injector harness ...........
I guess GM doesn't know what they are doing again Just about every GM vehicle is wired this way. It's common practice in power supply wiring in electronic equipment. If you have a wiring problem...fix it! The sense line is tied to the positive battery cable down at the starter solenoid where the fusible links are that power the electrical system. Sensing the voltage at the back of the alternator is actually the worse place to sense the voltage since it can't sense the true demand on the electrical system because of line drop in the feed line to the battery. It won't "over charge" the battery since the sense line is tied in just after the battery on a very heavy cable which has very little line drop.
.....I don't believe that a constant 12.5v at fuse panel during a WOT run will hurt anything or effect the performance of the car as long as fuel pump , injectors , & coils are not being " starved " for voltage ..................... Sam
Where Mike is sensing voltage is very close to the back of the alternator because of it being on heavy trunk line wiring . Nothing wrong with that , but maybe his ECM voltages improved because of marginal connections at the fusible links that were corrected when the sense lead was installed . What I'm saying is that the voltages dropping to 12.5 at the ECM during a WOT run should be ok as long as the heavy current draw components don't . You would need to monitor the voltage at the alternator to see if it is losing voltage as current draw goes up , or is it marginal wiring at the fuse block . If the alternator holds 13.5v-15v throughout the run ( monitored at the alternator ) and the powerlogger shows a voltage drop I think you found your problem , marginal wiring and or connection . Couldn't you run a dedicated wire from the alternator to a powerlogger input and monitor both voltages at the same time ? SamSo you do agree with Mike dynoman?
Generally dropping to 12.5 volts will not hurt or affect performance with street use, but at the track, especially in competition use, voltage must be consistent and much more than 12.5 volts at sustained WOT for proper performance as well as reliability in my world!
Another concern I have is most in-tank fuel pumps I have used specify 13.5 volts as their baseline of output performance.
Since I have a Boost-a-Pump inline directly from the battery to my external fuel pump on my race car, I am confident that I always have much more voltage there than needed.
On my performance street car, 12.5 volts would not be acceptable for me at WOT.
Your welcome.Thanks
