- May 28, 2001
Any progress on the project?
Just curious.
Just curious.
SignUp Now!Originally posted by Ormand
How did you pick the "target" A/F ratio? With a dyno, you might run at a fixed boost, and adjust timing and fuel for best power, no knock. Without tests of some sort, choosing an A/F ratio is educated guess work, you can get close, but won't be sure if you are right.
Originally posted by BoostKillsStres
I have a distinct feeling there's gonna be a whole new set of record times being run by people with stock type chips w/o the need to pay the big bucks and have the steep learning curve for the aftermarket fuel management systems....should be very interesting to see.
Gotta love high technology.
That sounds risky. IF you are lean and getting knock, it would probably work. But you can get knock running rich, too, and in that case it would make things worse, before they got better. As I remember the knock vs mixture curve, it has a little plateau, where knock is least likely, and then it gets more likely as you go either richer or leaner than the optimum mixture.How about a chip that watches for knock and will automatically add fuel when its detected
