wiring for a dist to old fast
Twin70BB
I have sent out the fast box and received the coil pack adapter from Cal.
Now how does this wiring work in line with a 7-al2 box.Cals plug for the cam sensor has a white 2 wire plug and the dist has a 2 wire weather pack plug.
Now where does the 7-al2 come into the scene.Also new balancer from dan is also in route with the relucter ring at 50 deg.
Tony
I would like to see a pic of the adapter harness. I would think the est output from the ecm would go to the points trigger on the 7 al box, but not sure, so you better get more instructions to be safe! This is how i am setting uo my ignition box on my gen 7.
Norbs is correct. You will need to take the white wire coming out of X3 and run it over to the points input of your ignition box. If you are using an adaptor harnes without a points wire, you will have to add this wire. If you need it, give me a call and I'll be more than happy to send you a points wire.
