turbox-tech
- Dec 7, 2011
Doing a swap into a 79 Malibu with a GN dash and just finishing up the harness. What I would like to know is if I remove the following from the harness will I have any issues? EGR, Fuel pump relay (using prime wire), A/C complete harness, Wastegage solenoid, and complete fan relay setup (low and hi speed)..using aftermarket relays (racetronix and Hayden). I may use the low speed wire as a A/C source to the Hayden Relay.
thanks in advance guys
