Wiring issues Need Help
kgeb3855
I removed the trans pan to change out the TCC it was hanging up and I noticed the plug on the side of the transmission is a blue plug with only 2 inputs to the trans the forward upper and lower, A & C I believe (front of car) and I am not sure how to properly wire the TCC I have the 3rd and 4th gear switch in the trans. the original wiring jumped from the 3rd gear switch to the 4th gear switch and then the TCC It also appeared that the hot side was run through the switches instead of the ground. Would I be better off getting the correct plug or can I run the positive to the TCC solenoid and the negative to the 4th gear pressure switch then to harness connector (there are 2 connections on 4th gear switch onlyh on e on third gear switch) I hope this is not confusing.
