- May 25, 2001
Is the Earthquake sub a dual 4 ohm or 2 ohm voice coil, depending on what your amp can handle (stable 4 or 2 ohm) You can wire it parallel for a 2 or 4 ohm or you can run it in series which is taking the positive to the positive of on voice coil and from the sam voice coil, come out negative jumper to the positive of the other voice back on the negative side of the same voice coil to the amplifier negative to create a 4 or 8 ohm load. Less impedence more power, more impedence less power but cleaner.
