I just removed my turbo and was wondering if this is an te-60 turbo, It spools fine 28-29 lbs with no play . I got it as an upgrade from a 49 turbo.I was seeing what would be the next size turbo to get with my sig. would like to get down to low 11's at around 120 if possible, i dont mind turning up the boost but for some reason i can only get it to 28-29 lbs i have ATR down pipe with an Atr waste gate and a bleed off valve opened up, any help would be appreciated thanks, pic belowView attachment 190219
I can see the first pic now...for some reason it did not show up originally! Bison is right...P trim. This turbo should go low 11's in its sleep with the right supporting mods.
thanks for the feed back on turbo question i'll be trying to get it down to low 11's when zmax has test and tune and when if finally stops raining, thanks again
