I have just performed the annual "spring cleaning" on 87 GN, when to my dismay, after buttoning up trans pan; I discovered not only the shifter handle was broken but the trans wouldn't shift out of gear, (not engaging other gears even when handle was out of Park position!)? Now, when the throttle return?? detent(or whatever it is that is to the side of shifter detent) has the pin pulled out, I can engage the gears?!! Another variable at work here is, the car hasn't been driven for awhile as I "repaired" a jam in the lock cylinder actuation rod on the steering column, (the rod was being caught on the shroud's interior tabs) could this be connected? I did remove the pan and inspect filter position, appears fine. Strangely, the pan and detent bracket each had a bolt missing. Any ideas, suggestions, or help would be appreciated!
