won't start sometimes hot
glenn c
Won't start sometimes when hot...starts everytime cold. Good fuel pressure so must be electrical, anything I can check with turbolink? Crank sensor? Coil pak? etc.
Does the tach move when trying to start it and it won't start?
Swap a coil pack and module with someone....module can do this.
I am assuming that you mean it cranks over but does not fire.
Ok now...i swapped several GOOD coil pack/modules with same results, no spark & no Inj Pulse when motor hot 180*
If I change the hot coil pack/module with another coil pack/module then motor will start or if I wait for several minutes with hood up then motor will start. Evidently the module is getting heat soaked when sitting cause no bad symtoms occur when driving.
