I have read a couple of threads out there that indicate you can lighten up a specific weight in the transmission and gain additional RPM in your wide open shift points.
I would assume the lightening of this weight will also change your part throttle shift points, is this true.
Are there any negatives to this method for changing shift points?
I was looking into a mod offered by CK Performance, but it is pretty costly.
