TT/Ameasap
The White Blur
- Jan 31, 2002
Haven't had a chance to play with it yet. Been real busy lately. Should get to it this week If I don't get sick... Family is down with a nasty littl bug.
Keep in mind higher amp alternators will not solve low voltage problems when wiring is the issue. The other draw back of higher amp alternators, they take more rpm before they make power. At idle they don't make power and if you don't upgrade the wiring, it's useless.
Best bet is to take the aftermarket load off the factory fuse panel and run separate power feed inside the car to a relay and use that to power accessories. System voltage will then increase.
Rick
cool thanks!
Seems encouraging...I'll try a 15 amp fuse vs the 10 amp. I'll see what my volts are after getting that new belt on. If I have to go with a 200amp alt. then thats what I'll do.
Also noticed if I turn everything on like, lights,radio,HS fan, and it will read 13.0- 13.2 at idle
When its normally 13.8-13.9 at idle
Running E85 and no alky. Now im at 13.3-13.4
With lights on or off?Running E85 and no alky. Now im at 13.3-13.4
