Thanks but unfortunately these files are useless on a T-Regal.Is this what your looking for?
I'm working on the XDF file posted earlier in this thread by Turbo1dr.
I hope to have it finished, or at least ready to post later this week. The file contains alot of good stuff and although I'm adding a few more items, the most often changed items are in the original file.
I'm just adding comments, checking everything (calculations, labels, etc.), and making all temperature values in degF. There are enough entries now that I thought adding "categories" would be helpful. I find it much easier to find what you're looking for if you can display just related items, like "spark advance" or "idle control" for example.
Carl, if you read this, I converted your ECU file and it works fine. I went with the EDF file from Turbo1dr because it has everything that's in your file plus more. I think you'll like the new version I'll be posting soon.
When I'm done we'll have a complete (and accurate) XDF and ADS file for the 86/87 T Regal and it will be "open source".
