Gents-
I just noticed my scan-master IAC numbers on norm temperature, idle is 65!!! when from what I read should be 15-20? . I checked my RPM's and they were at 950 or so....went ahead and pulled back the Idle Air Control Adjustment Screw as far as it can go and the rpms dropped to 850. I understand the RPM's on IDLE should be 500-600.
Are my assessment correct and if so WTH could be causing the IAC to be so high? Also my BLM is 128 which is perfect so no lean condition...its rich as all hell and idles and runs like
I have a ported 62mm TB and recently replaced the IAC Selenoid about 8 months ago.
Should I check the inner air outlet ??? I did experience oil seepage in my plenum via a stock PCV valve a few weeks ago and since replaced it with a unit sold by RJC.
Any ideas please?
Any ideas please?
