p/s asloan5 in that same area you will find a ICT file called default learning..i used this as well...
Ok I am embarrassed I missed this but Cal help me and now she runs like a top!!!
Under fuel tables, the injector offset vs battery voltage was at the generic setting, that's what caused all the trouble...
So...after connected to car (online with box but veh not running)go to file, then paste from file...open the ICT folder....then open the injector offsets folder and pic your injector...then hit ok...
Then be amazed at how good the car now runs...I was
****THANKS MR CAL HARTLINE****
I hope this post saves you some calls!!!
-Dan
I guess you didnt read my post in Cal's other thread![]()
how do I apply that default learning file.
and thank you
cal I sent you an email about the wot tune
Thanks all Albert
Changes all the values for the learning tables from the preset to something that is actually functional.
what does the default learning file do ?
Allan G.
pretty much exactly the way you do the injector offset file the learning is just there in the list with all the other folders....not in a folder....i missed it the first time too
Is this were you turn the self learning on and off Dan.Thanks
