Chrisk
TurboTransAm.com
- Apr 12, 2005
Friends car will not make more then 13 psi of boost no matter what the DC% is at.
I opened the wastegate and put in a total of 21 psi worth of springs. Car now make 21 psi of boost. Again changing the DC% makes no change.
Is the solenoid bad? Should it click with the key on engine off?
Boost prams are set to open loop, over boost setting is at 300kPa
Running ver. 2.051 w/ latest firmware.
Thanks,
Chris
Thanks,
Chris
