Just go to the throttle follower table and raise the green line up at 0 TPS. if the idle goes up, it's working
OK, well I thought I had a bad Accufab throttle body so I wanted to wait to call you while I borrowed a buddies to see if that would help. After getting the IC pipe and flipping the throttle a couple times and then flipping the borrowed throttle blade a couple times, all seemed good with my TB. It's will stick a little while closed but no more than the borrowed one.
Soooo, I decided, what the heck, I'm going to swap out the IAC and see what happens. Well, the car idles at exactly 1000RPMS now. I did check the IAC in the Throttle Follower and it did raise when I raised the IAC at 0 TPS but for some reason the new IAC motor smoothed it out. Kind of odd?
Anyways, I'm happy to say I burned my first tank of E85!!! Funny thing is I didnt even have a chance to get the car out of the garage!
Anyways, Cal, now that I got the throttle figured out, I am going to call you if I can get out of work early enough. I am guessing I will be out early tomorrow because it is supposed to rain. I just want to make sure I have the timing correct and double check a few other things while I have you on the phone.
THANK YOU GUYS VERY MUCH! IT MEANS A LOT TO ME! This has been a huge long term and expensive project but hopefully I will get a chance to enjoy the car soon! -------Jeremy
