Ok, heres my situation. Ive got an 87 GN with 57k. Its been sittin since 2002 when it was wrecked. I had to replace the brake and fuel line on drivers side frame rail after I bought the car in January this year. I also went ahead and did the aluminum drums, 7/8 wheel cylinders, new shoes, new pads and turned rotors on front. It "appears" to have a new power master motor allready on the car. When the switch is turned on, the motor will pump up the system for maybe 3 seconds and stop. When you press the pedal it will go straight to the floor and the motor will run the entire time untill you let off of the pedal. I have tried the bleeding procedure on this site writtin up by Zuess and also the info provided on GN/TType.org with no luck. Anyone have any suggestions other than switching over to vaccume or hydroboost? I have enough p/m brake systems lying around the shop there should be enough odds and ends parts to fix it but have no idea where to start. I tried the acc ball and press switch allready.
Thanks in advance guys.
Brian
Brian
