In years past I would build 5lbs on the first yellow then creep into the second yellow ready to go. On green I would floor it and let off brake at the same time. I see the other posts where it is recommended that you floor it then let off brake a split second later. I assume the idea is to build more boost?
Which technique is more popular? Thanks
