8 87Turbo-TWE4 Member Joined May 9, 2008 May 16, 2010 #1 Does anybody know off the top of their head how many fittings there are in the front suspension for lubrication purposes.
W Waco84GN Member Boost-aholics anon Joined May 25, 2001 May 16, 2010 #2 Lemme try.... 2 upper ball joints 2 lower ball joints 2 outer tie rods 2 inner tie rods idler arm and I believe 2 zerks on the center link maybe 11? Good luck, Jerry jr.
T TURBOTWIN2 ASE CMAT L1 Joined Jun 17, 2005 May 16, 2010 #4 Idler arm doesn't have two grease fittings? Check again.
8 87Turbo-TWE4 Member Joined May 9, 2008 May 17, 2010 #5 Waco84GN said: 2 upper ball joints 2 lower ball joints 2 outer tie rods 2 inner tie rods idler arm and I believe 2 zerks on the center link maybe 11? Good luck, Jerry jr. Click to expand... Those are the ones. Thanks.
R regal81455 Member Joined Oct 20, 2008 May 17, 2010 #6 you may need a few more for the ones on the upper and lower control arms, if you have aftermarkets...
