SAVANNAHAUTOAIR
AUTO AC AND COOLING PARTS
- Jan 6, 2005
Hi, a friend of mine is having trouble with his GN...basic goal is to get it into the 12's. Below is the text he sent me, and my opinion, is that he needs to get the boost up a little above 20psi, and he'll be where he wants to be.
The main thing that bothers me is that he says it is shifting into OD...
Thanks, Brett
Here's what he sent me:
The list of mods are as follows:ta-49,009 injectors,rjc powerplate,adj. fuel reg,adj. wastegate,atr headers and 3 inch downpipe with dump,2 3/4 inch exhaust,fred brown trans and 2800 converter,turbo tweak chip,vdo guages.
There was some type of cold air kit on the car that located the air filter under the bumper but I took that off on Saturday and installed a cone filter behind the headlight.
I use a scanmaster 2.1.Some of the mods were on the car when i bought it(headers,adj reg and wastegate,trans and exhaust).My first pass with the car got me 13.70 @ 97 mph.Now the car goes 13.5 @ 98 mph.All runs were made on street tires so I wasnt able to build boost on the line.
Opening the dump didnt add or take anything away.I also installed a rjc boost controller because my boost wouldnt go above 15psi.Well it still goes to 15psi it just gets there faster.
Also because of the non lock up i have to let the car shift into 4th on the track.My scanmaster readings show no knock and O2s are 720-790.
I just want to be able to get the car in the high 12s in order to keep up with my friends.I dont want a bruiser because Ive already got one(88 Mustang LX with a blown 331 stroker).
Thanks, Brett
