1/4 mile time
turboman38
It costs money to go fast
Ok I know this is tough to guestimate but I wanted to know what you guys thought my car would run given what's done to it.
TE 60 turbo
50s for injectors
206/206 cam
TH downpipe
3.73 in the rear
2700-2900 stall modified stock convertor
stock intercooler and heads
I have all the necessities for fuel delivery (regulator,hotwire,pump). Motor has about 8000 miles on it but the bottom end is new. I bought new GM crank and rods and had 30 over TRW forged pistons installed. Steel caps in center. I will be running 26X10 slicks with an airbag in the right side. Launch will be with as much boost as the new stock S-10 wheel cylinders will give me. I'm running the J Carter boost sensitive chip on the street but would like recommendations on what chip to run at the track.
Does the car have a mid to high 11 in it the way it sits?
26" tires and 3.73's will hurt you in your quest for mid 11's even with a cam. It will launch hard, but getting more than 112 mph out of it will be a tough trick with stock heads, even with the converter locked.
