1 owner 87 Turbo T for sale
Boostrules
Original owner 1987 Buick Turbo T 102500 miles $29,999. Have all paperwork: Dealer invoice, window sticker, build sheet, showroom brochure etc.
Completely repainted in 2008, door jams, inside trunk lid, inside hood in original Gun Metal Grey. Came out way better than the original GM paint job. Never saw inclement weather and garage queen ever since. Only comes out when there’s no chance of precipitation.
Transmission external cooler since new
Air breathers both valve covers since new
Kenne Bell performance 17lb chip
Kenne Bell 2.5” stainless steel mandrel bend dual exhaust with Pypes violator mufflers
Straight pipe replacement for catalytic converter
Monroe shock absorbers
Kenne Bell ram air kit: front air dam with intercooler scoop, air cleaner inlet, turbo cooler inlet
K&N Air Filter (washable)
Power Master Assembly Complete (New)
Brake accumulator bowl (Kirban)
Engine mounts (Kirban)
Headliner abs replacement (Kirban)
Visor and visor mounting bracket (Highway Stars)
Scanmaster G gauge (Full Throttle)
Autometer Boost/vacuum gauge (Full Throttle)
Fuel pressure gauge (Kirban)
Custom cut High Performance grey plug wire set (Kirban)
New plugs AC Delco R42TS gap 30
Billet Aluminum adjustable fuel pressure regulator (Kirban)
Hood gas shocks (Kirban)
New TCC solenoid valve, new filter and Transmission Fluid
Rear differential gasket and fluids (Posi)
Comp Cams 980-12 92 lbs Valve springs and intake manifold valve stem seal gaskets
Timing Chain gears and tensioner Set
New turbo Silicone hoses with T clamps (Full Throttle)
Maf Pipe kit 3” (Full Throttle)
Denso oxygen sensor
Driver side 409 Stainless Steel Header Kit (Kirban)
Crossover Pipe 14 gauge 409 Stainless Steel (T.A. Performance)
Delco LT1 Mass air flow Sensor (Kirban)
MAF Translator (Kirban)
160 degree thermostat
Serpentine Belt
Water Pump
Replacement Radiator hoses upper & lower, bypass “S” and heater hoses (Kirban)
Reproduction Heater Core (Kirban)
New Fuel Tank
New Fuel Filter
255LPH Fuel Pump & installation Kit (Full Throttle)
Racetronix Black Hot Wire Harness (Full Throttle)
Body Ground Upgrade Kit (Full Throttle)
Get Back Seat Brackets 3” extension (TR Custom Parts) I’m 6’2”
Smoke Headlight Covers (TR Custom Parts)
New Battery (Diehard)
New Tires (225/60R 15) General
New Wheel Lug Nuts solid stainless steel
Have all the original parts, most modifications are bolt on and can be returned to original.
I’m sure I’m forgetting some of the upgrades but the car runs strong, never been to a track, never beaten or abused. All maintenance done before it was due. She’s been my baby for 37 years, now it’s time to pass her on to someone younger who will appreciate her.
Denso oxygen sensor
Serpentine Belt
Water Pump
New Fuel Tank
New Fuel Filter
Where is it located? Any pics under the hood and under the car?
Denso oxygen sensor
Serpentine Belt
Water Pump
New Fuel Tank
New Fuel Filter
Thanks all for the kind words and likes. I was limited to 10 pictures when I first posted. I can take some pictures of the engine bay but warn you that I've never prioritzed detailing the engine compartment. Don't have a lift but can take some shots of the undercarrage from the front and back. I'll try to get that done today.
I'm located in northern NJ, Sussex county.
Here's some pics from the engine bay and undercarriage. Don't make fun of me for the dryer hose turbo cooler. I've already heard it all, where do you put the dryer sheets, where's the lint trap go, etc. Thats why at car shows I leave the hood closed. Since I wanted symmetry on the Ram Air Dam I went for the 2 openings, probably does nothing to decrease turbo bearing temps but it makes me feel better. Tried to show the upgrades in the engine compartment, header, maf, fuel pressure regulator etc.
