Is anyone running 10" wheels on a stock 87GN wheel well. Whats the disadvantage of running 10" rims compared to 7" or 8". If anyone is running or knows of someone running 10" wheels did you have any problems?
The fender lip will have to be rolled very tight or removed completely. You will need the correct back spacing are the wheel will be sticking out from under the fender, assuming that you haven't nocked the frame. If you have nocked the frame then the 10" wheels fit.
Why do you need 10" wheels
I am running 305x50x15 on 8-1/2" Vectors with 3-7/8" BS, with only a slight bulge. Of course my fender lips are rolled very tight.
