Therealbobjones
- Jan 5, 2022
Up for sale is my 1987 regal.
Eng- SBC 383 Stroker w/Holley Sniper EFI, Ported Edelbrock RPM Air-Gap Intake, AFR
195cc cylinder heads 100% CNC machined (2.05 int/1.60 exh valves), 1.5 aluminum roller rocker arms. Comp Cams XE 288 Hydr.roller cam, Scat
9000 Crankshaft, Forged Scat pistons-connecting rods w/7/16 ARP bolt upgrade, MSD Pro billet distributor, MSD wires, double roller timing chain, Comp Cams 2pc billet timing cover, 7qt oil pan, March underdrive pullies. 1-5/8
Hooker Competition long tube ceramic coated headers, St.Steel X-pipe, 40 series S.S.
Flowmaster mufflers. -6AN braided fuel line, 255gph Walbro fuel pump w/upgraded Racetronix Hotwire kit.
Drivetrain-
Professionly built Coan TH350 w/reverse manual valve body w/aluminum deep pan, Coan 9in. 3500 stall torque conv., SFI certified flexplate, -6AN braided cooling lines, B&M heavy duty plate type Trans cooler, Aluminum radiator, 3 1/2in aluminum driveshaft w/Sonnax heavy duty u-joints, 3.55 Richmond gear, 28 spline Eaton Detroit Tru Trac Posi unit, 28 spline Moser Engineering Street axles w/3in wheel studs, Axle tubes welded to center section, Moser differenrial brace.
Suspension- Polyurethane body mounts, UMI tubular adj. upper-lower front control arms, ProForged 1/2 in taller upper-lower ball joints, Gforce crossmember, UMI tubular adj. upper-lower rear control arms, UMI adj. rear control arm braces, UMI 3 way adj. rear sway bar.
Belltech Street Performance front-rear shocks, Moog lowering springs. ZQ8 front bump stops, Baer bump steer kit, Kirbans rear seat X brace.
Wheels- 17in. Centerline wheels. 245/45
Nitto NT05, 275/40 NT05R Drag radials.
Brakes- C5 Corvette Z06 front-rear drilled/ slotted rotors-calipers, Stainless steel brake lines.
Audio- Pioneer 1.5 din flip up head unit.
Misc- All brand new front end susp, steering components. Fragola fluid lines, Autometer Ultra Light 2 5in. Tachometer, 2 5/8 Ultra Light 2 oil press, water temp gauges w/steel braided lines, 145mph speedometer, Lokar oil and trans dipstick tubes, shifter, throttle cable. 140 amp alternator, brand new ac delco battery. Weiand aluminum water pump, Tuff Stuff power steering pump w/PTFE lines. New fuel tank. Canton aluminum valve covers. Dual electric cooling fans, ARP bolts. New heater core. New weather stripping.
Brand new upholstery on front and rear seats. Grey floor mats from Highway Stars with the red T.
Paint in less than a year old. Painted in PPG 2012 Cadillac triple black diamond.
Drivetrain-
