Mar 17, 2006 #1 J jerry1967 New Member Joined Mar 17, 2006 Messages 7 when i start my car it runs for 1 or 2 seconds and then stalls with smoke coming out of the tail pipe. does anybody know what this is.
Mar 17, 2006 #2 C CTX-SLPR Active Member Joined Feb 4, 2004 Messages 1,932 www.clubgp.com www.regalgs.org those will be better sources for an answer for a Series II 3800 question Is it an LS or a GS? if its an LS you probably have had the EGR burn through on the L36 composite intake. Go down to the Supercharged 3800 Tech forum down the page and look for the post 3800 With Water in Cylinders . Sounds like your problem.
Mar 17, 2006 #3 C CHARGED Member Joined May 24, 2001 Messages 607 Fuel pump resistor or relay?gone bad. Mine did the same thing but don't remember any smoke
