Howdy folks! I dropped by as the Vintage Van guys didn't respond to my inquires yet.
To cut to the chase, I have a '69 GMC van that I swapped a 200R4 into, which refuses to shift out of 1st.
It goes to P, R, N, and 1st just fine, I even burned out in reverse a bit when I got mildly stuck backing into the driveway.
Going in 1st, it goes until I basically rev out the engine. Then I let it drop a bit, and it catches again.
Now, I did do the forum search, and I did go out to get a new governor. No cigar, still same issue.
I tried to pull on the TV cable while moving. The more I pulled it out, the less power transfer I was getting.
I checked the pan, and apparently there was white sludge in the bottom. Looking at the filter though, none of it seemed to have been pulled up, filter was changed anyways.
The transmission is supposed to be a 0 mile rebuild, nice and clean, and it did have a cork in the filler hole.
Suggestions?
Suggestions?
