237 regulator
JeffRender
I seen a picture from another post that had a 237 regulator with an aftermarket adjustable top. Does any one know who sells this item.
Also what are the limitations of the 237?
Jeff
If it is adjustable there aren't any. I bought my billit top from a guy named Gary up in Canada.
Originally posted by JeffRender
It is not adjustable.
Stock 237 came on the sumerset and TTA. For a stock motor with stock Injectors it will be ok.
I would strongly recomend getting an adjustable on.
Jeff
I have seen that one too. It was like someone rigged up a 237. I wouldn't bother with it. If you're gonna get an adjustable, then just buy a new one.
I have been happy with my 237, but I am ready to move on now that I have a scantool and have started to really adjust boost. They make the FP 45 lbs and go well with Thrasher 92 chip and a basically stock setup. They are on the 3800 series 1 motor (late 80's full size GM - FWD), so they are a dime a dozen in the yards. I see about 18lbs with my combo on pump gas. When the weather cools, I get a little lean and start to see some knock at that boost.
Good news is, at about 10 clams, you don't lose much to try it out.
Jeff
So is it adjustable or not...?
