I am looking for some advice. Will 245 60 15's fit with out rubbing or scrubbing the the car on stock GN rims? Or if in doubt just stick with 235 60 15's.
Thanks in advance
You'd probably be alright with the 245/60/15s on the back but they may rub some in front. A lot depends on the state of your shocks and springs. I'm running 275/50s on the back and 225/60s up front on my car.
I just put 235/60 on the front and 255/60 on the rear. No worries on clearance, but I didn't think I could fit a 275. Aren't 275/50 ~25.5" tall, and 275/60 ~28" tall?
Question 1: Are they on stock GN rims?
Question 2: If so, are your 87 rims the same size/BS of the 85 GN/ T rim?
EDIT: just found this:
"""15x7 with 4" BS is the same as the original GN rims, not the same as the Ttype rims though which had 3.75 BS.
275/60/15 will fit on the 4" BS, 275/50/15 will not."""
I'm about to put new front tires on my 87 GN with stock rims. Backs are BFG 255 60 15's. Has anyone had success with the 245 60 15's on front? or is it safer to go with the 235 60 15's?
