26 PSI on pump gas run video
Razor
Forum tech Advisor
Staff member
http://www.bmcomputersource.com/pachires.wmv
This was done yesterday, conditions were no where near optimal, ATS was 110, outside air temps was 95 degrees humidity at 95 percent. Engine was at 175 for coolant.. Was fun..
First time anyone ever sat in my back seat..what a way to christen it.
Do not try this at home kids...closed track under secure conditions :D
Engine combo stock everything but turbo(PT51), MSD 50's, comp springs,160 tstat, THDP, updated spark plug wires, fuel pressure regulator. Rest of motor is 100 percent as delivered from GM
Even runs a thrasher 92 street chip.. hence the timing numbers on direct scan.
Look at the transitional knock when floored..zero
Wonder why? ;)
Goes into full production this coming weekend..will post :)
