I wanted to get some thoughts on my 4.1 production block build. I got to looking at the front cam bearing a little closer last night and started to question the way the bearings are installed.
Here's what I can tell you.........I know I have ACL grooved cam bearings (grooved on backside), I'm not sure if they have one or two groves on the backside but I was told they were grooved. Here's the deal that concerns me, the front bearing only has one oil passage drilled in it & it's at the 8/9 o-clock position. I will be using a flat tappet cam & it also has a groove in the front cam journal. Would you feel good about running it like that? I know most front cam bearings has two oil passages, one at 8 o-clock & one at 3 o-clock. The guy that did my machine work wasn't a Buick man & if he would have just installed the HD Dura Bonds like I asked for I wouldn't be so up in the air, trying to figure out if I'm ok.
What do you all think.....
