400 turbo transmission Question.
278cikiller
I have a lead on a 400 turbo transmission, what numbers and other markings should i look for to make sure it's the right one, Thanks.
Just make sure it is the BOP bolt pattern. Kick downs were different but you probably won't use them.
No but it will have the 2 lugs that stick up for the BOP top bolts. It should look just like the 200r4 bell housing.
This is a BOP short-tail TH400:
