4x4 question
Little6pack
my 89 S-10 4x4 is not engaging into 4 wheel drive.
I have read up on some forums that say check for vacuum leak at actuator.
where is it? my hayes repair book doesn't show it.
The 4 wheel engaged back in summer but now that the snow is here I get nothing. the light up display doesn't even show the front wheels engaging.
The shifter moves into 4-H with no problem.
Passenger side, under battery tray. Will pull vac. when lever is moved to 4wd thru a $54 swithch on the t-case. Pulls a cable that goes to the front diff. Common quick fix is to use a manual choke lever connected to the actuator ball.
