50 lb injectors and stock hotair computer.
Rob_85Ttype
I'm getting close to installing my rebuilt engine, which has been reconfigured to 86-87. I have 50 lb injectors for the buildup, but haven't yet installed an 86-87 computer with aftermarket chip. I'd like to crank the engine with the stock computer since I know it works, and I want to fire the motor right away to break in the cam properly. Can I break the engine in with the 50 lb injectors and the stock hot air computer, or will the two not be compatable?
Is there a 50 lb chip for the hot air ECM available? The thing I'd like to avoid is not wiring something properly the first time, then being unable to crank the engine.
