79 lb/hr high impedance injectors
ds4545
Has anyone used the 79lb/hr high impedance injectors? I saw them at GBody parts and states that they can be run with stock ecm.
79lb injs
I run them on my car for some time now. run them with 6765bb turbo with tt chip and gn1 heads and intake. so far no problems runs good and very steetable.
Yes they will work for a stock ecu, they are high z injectors. IF they were LOW z injectors you would have to have you injector driver in your ecu upgraded.
