For sale as a pair: $85/shipped.
These chips have tunable parameters that are accessed by turning on the parking lights. I only have one of these wires (can't find my other one), so I have to sell as a set, UNLESS you already have the parking light wire installed into your ECM harness.
Extender Extreme Documentation at Full Throttle Tech
ESU57C0F (street) -
ESU77C0F (strip) -
Both are known good. I've upgraded to the EE Revision G that allows me to change timing via my Gen II Translator. Both work with the Gen II Translator (just no timing adjustments).
These chips retail for $120/ea + S/H new!
ESU57C0F (street) -
- Stock Data Stream over ALDL
- 83# Siemens injectors
- 23 degrees lo-gear WOT timing, 21 degrees hi-gear. You need alky injection!
- Wastegate 100% about 20 psi with stock wastegate
- 850 RPM idle and 6200 rev limit
- No anti-theft
- Revision F
ESU77C0F (strip) -
- 27 degrees lo-gear WOT timing, 25 degrees hi-gear. You need race gas!
- No anti-theft
- Revision F
