83 hot air
I wanna say o2 and TPS????? NOT FOR SURE THOUGH. I'd try the b4black site. Rule of thumb-start with lowest code first. Usually
What was the codes? was it lean or rich o2, high or low voltage tps? Maybe I can help you out some
TPS high??? Hmm. Hook a volt meter to it and do your checks, You should be able to find this info on the gnntype.org site. I don't know what the low value is though. It should say in the haynes manual. It probably won't be the same as the FI cars so make sure your info is correct. If you cannot find the info you need get in contact with Freddie or Rich George (B4black). Good luck! I'm sure once you get the TPS prob fixed you should notice a slight increase in driveability. THe TPS is a biggie. It controls a lot of things.
Replaced tps with another from another carb. All good now,thanks for the help.:wink:
