I am hoping someone can help me out. I have a stock 84 Grand National that I a purchased new. The car has 96,000 miles on it and has only been driven in the summer since 1988. My problem is that when the the outside temperature is 85 or higher, the car will not start when the engine is warm. After a cold start the car runs fine until you start to slow done/idle, then it runs rough like it is flooding. If you shut the engine off and let sit for 5 min or more, it will be 30 minutes before it can be restarted. During that time, if you crank the engine, it will only fire (generally only one or two cylinders just after you start to crank the engine) with the throttle in the full idle position. Trying full or part throttle will not get any firing.
I have replaced all of the vacuum lines, replaced the injectors and the throttle position sensor.
This happened to me a couple of nights ago. It was 90 out and I drove to town to get gas. The tank was reading 6 gallons. I noticed that when I removed the gas cap, there was a lot of pressure in the tank. Could this be related to the problem? Any suggestions would be greatly appreciated.
