84 performance parts?
ryan77
I have the intake off to do gaskets what should i do to gain some performance while i have the intake off.
depends on your wallet, performance heads, upgrade your head gaskets so you can run higher boost, 42.5 injectors, fuel pressure regulator,
you can port and polish the intake for not too much at a decent shop...get it gasket matched... Eventually, it would be great to get the heads matched as well... Definately upgrade the injectors and chip (and fuel pump) if your $$ permits... Easy to do with everything out of the way...
What do you have done to the car currently?
john:smile:
i havnt done anything to it yet i have a oil leak on the intake and valve covers so thats why i have it off, what injector and chip do you recomend.
it seems like most people with hot airs tend to go with the 42.5's. i was told that anything higher could flood the engine on our models by poston. Turbo tweak makes a good chip!
