GranRegal87
- Jun 18, 2004
Hey guys.
I "Searched" all of the forums and got a ton of useful information but still have some unanswered questions..
I have a 1984 Regal Limited with a 3.8 V6 and a 3 speed auto tranny (no overdrive).
I obtained a complete 1985 Buick Grand national, Motor, turbo, tranny, wiring harness and computer. I plan on swapping out my 1984's drivetrain (when the motor starts knocking) for the 1985 GN's.
All of the turbo swaps I've read about is using stock fuel lines, and adding Hi-pressure fuel pump and GN tank, and welding a new cross member for the tranny.
I guess my questions are..
1. I plan on running a fuel cell in the trunk with a sump, an in-line high pressure fuel pump, filter, and AN lines to the motor.
Will this screw up my emmissions? I am in NY so, it has to run the standing idle test or maybe a Dyno test at 50mph.
2. Since my car came with the 3.8 liter V6, is the correct crossmember already in the car? If not, are there aftermarket cross-members available? I plan on running single 3" exhaust dumping on the right rear tire before the axle.
3. Will I run into Wiring harness/ECM problems using the stock 1985 engine harness and computer and reusing my 1984 body harness/other harnesses? Or should I start looking into an aftermarket custom GN engine harness?
This will be a daily driver but I want it to be fun, so I'm tearing down the motor and freshening it up, putting a chip in it, free flow exhaust, intake and maybe some head work.
Anyone have any recommendations for best bang for the buck on a Hot air setup? I'd like to run low 13's all day, maybe dipping into the 12's..I think that's being pretty realistic compared to some of the hot-air recipes I've seen..
Any other info would be greatly appreciated..
Thanx in advance!!!
L8r
Thanx in advance!!!
L8r
