I have a new set of 1985 turbo headgaskets. They are steel with some sort of coating on them. They are made by Fel-pro 8723 I think. I usually use RJC steel headgaskets with the adhesive. These Felpros are clearly not the same embossed type of gaskets, but I wonder if they could be used with the adhesive as well. I know the deck height is also different on a 109 block vs a hotair 85 block. If I were to used these 85 geadgaskets on a 109 block, how would that affect the compression ratio? Any ideas?
