86/87 ENGINE WIRE HARNESS
PaulRV6
Looking for the engine harness and also the male end on the injector harness. This doesn't have to be in mint condition bc I may be modifying it a little. I have a hot air engine that I am converting the electronics to 86/87. Thanks
I have a harness its been modified but was working when removed. I believe i have an injector harness as well if you need one.
I'm in Chicagoland area, I have one I took off my car to go a completely different direction. LMK if interested on it.
SFICUTLASS, can you explain more of the harness you have? For some unknown reason I deleted your post, not sure how. Thanks
Harness has a splice on the coil pack connector, new pigtail from caspers spliced in for the air temp sensor and currently has an oil pressure pigtail for a pontiac fiero spliced in for my analog gauge to work on my cutlass dash. Asking $300 shipped
