86-87 header question??
Camfreek
Thanks Rob!!!
Ok when I got my 84 GN there was a passenger side Postons header and cross over pipe in the trunk. Seeing that my passenger side header was cracked to hell I replaced it with the one in the trucnk and put the cross ver pipe on as well. I have the factory 84 drivers side header still in the car but had to weld it up. The question I have is this. Is the drivers side header from a 86-87 IC car goint to dump out in the same spot as my 84 header and but right in to the cross over pipe as well??? And also does the 86-87 header flow better then the 84-85 header???
........ The question I have is this. Is the drivers side header from a 86-87 IC car goint to dump out in the same spot as my 84 header and but right in to the cross over pipe as well???
Yes, HA and IC DS headers are the same.
........ And also does the 86-87 header flow better then the 84-85 header???
If you are still talking about the DS side ........ See above
So it does flow better?
So the drivers side header will interchange from the years? But do the flow the same or is one better then the other?
There is not any performance increase with the drivers side header nor crossover pipe. Just make sure there are no leaks. Brad
Ok guys!!
The thing I noticed is the header on my car runs all three pipes and they meet up at the flange. I hope you get what I am saying???
Look at the guy that is selling the motor here in the hot air section for 500 bucks, do you guys see the driver side header on his car? The header on my car does not look like that:confused: I can get one like the one he has on his motor dirt cheap and it looks like it would flow better then mine.
Just wondering. Thanks guys.
