86 gn hardtop tampa fl
ytrya6
FOR SALE $13,000 1986 GN HARDTOP WITH 88,710 ORIGINAL MILES AND 2,399 MILES ON NEW ENGINE
I AM THE 3RD OWNER THE PREVIOUS OWNER PURCHASED IT IN 1991 WITH 51,000 MILES
IT WAS ALL STOCK TILL I PURCHASED IT ON 11/07 WITH 85,000 MILES SINCE THEN I MODIFIED IT WITH MANY PERFORMANCE UPGRADES THAT INCLUDE:
* NEW PAINT JOB BASE COAT/CLEAR COAT
* NEW ENGINE
* DOUBLE ROLLER TIMING CHAIN / NEW WATER PUMP
* TA 49 TURBO REBUILT BY PRECISION TURBO
* 3" DOWN PIPE WITH EXTERNAL TIAL WASTEGATE / MANUAL TURBO BOOST CONTROLLER BY TURBONETICS
* PRECISION TURBO SAVER OIL FILTER RELOCATOR
* BIG MOUTH AIR FILTER 4"/3" FROM MARK AT TR CUSTOMS
* FRONT MOUNT INTERCOOLER FROM GN1 PERFOMANCE
* DUAL RADIATOR FANS/WITH RMI-25 ADDTIVE
* B&M TRANNY COOLER
* 10" 3000 LOCK UP CONVERTER
* SMC ACHOHOL KIT
* 60LB FUEL INJECTORS
* TURBOTWEAK STREET CHIP 5.6v
* ACCUFAB ADJUSTABLE FUEL REGULATOR / FUEL PRESSURE GAUGE
* FUEL PUMP UPGRADE & FUEL PUMP HOT WIRE KIT
* SCANMASTER 2.1
* CASPERS V-PLUS VOLT BOOSTER
* LS1 MAF SENSOR
* MAF TRANSLATOR
* HOOKER 2 1/2" DUAL EXHAUST
* DUMP/TEST PIPE
* EATON POSI REAR
* EIBACH LOWERING SPRINGS
* BILSTEIN SHOCKS ON ALL CORNERS
* DRAG AIRLIFT AIRBAGS LEFT & RIGHT
* ALL LOWER BODY BUSHINGS FROM KIRBAN
* REAR SEAT BRACE FROM KIRBAN
* FRONT FRAME BRACE
* ENGINE TORQUE STRAP
* S10 REAR BRAKE CYLINDERS/ FRONT & REAR PADS
* WELDS DRAGLITE RIMS 15" 15X8 REARS / 15X 7 FRONTS (ORGINAL STOCK GN RIMS INCLUDED)
* TIRES BFGOODRICH T/A DRAG RADIALS 275/50 REAR FIRESTONES 215/65 FRONT
* ALL WEATHERSTRIPPING NEW
* NEW HEADLINER
* BRUSHED ALUNIMUN OVERLAYS ON DASH, CONSEL&STEERING WHEEL FROM MARK AT TR CUSTOMS
* TRANNY SHIFTS SMOOTH AND STRONG WITH NO ISSUED/WAS FLUSHED WITH NEW FLUIDS AND FILTER
* A/C BLOWS COLD
* VDO BOOST,OIL,VACCUM & TEMP GAUGES
LIST OF NEEDS:
UPPER DOOR PANELS DRIVER SIDE HAS A RIP (need re upholstery)
POWER SEAT WORKS BUT GEAR COUPLING BROKE OFF ( I INSTALLED A MANUAL SEAT TRACK)
STOCK RADIO DOESN'T TURN ON
WILL INCLUDE STOCK: RIMS, TURBO , INTERCOOLER, AIR INTAKE etc.
I HAVE ALL RECEIPTS AND A BINDER OF DOCUMENTATIONS OF PREVIOUS OWNER REPAIR AND SERVICE RECORDS
I GUESS SINCE I AM NEW ON THE SITE CAN'T POST PICS
GO TO ----------> s942.photobucket.com/albums/ad269/ytrya6/
