UP FOR SALE  IS MY 86 GN WITH 87,687 ORIGINAL MILES AND 1,376 MILES ON NEW ENGINE
I AM THE 3RD OWNER THE PREVIOUS OWNER PURCHASED IT IN 1991 WITH 51,000 MILES
IT WAS ALL STOCK TILL I PURCHASED IT ON 11/07 WITH 85,000 MILES SINCE THEN I MODIFIED IT WITH MANY PERFORMANCE UPGRADES
I HAVE OVER 12K IN THE CAR IN UPGRADES ,DRESS UP AND MISCELLANEOUS PARTS AND ALL RECEITS TO PROVE IT . I HAVE OWNED SEVERAL GN'S AND TURBO T SINCE MY TEEN YEARS & I THOUGHT I WILL HOLD ON TO THIS 1 FOREVER.
PLEASE NOTE ALL ITEMS LISTED WAS RECENTLY DONE WITH IN THE PAST SEVERAL MONTHS:
NEW ENGINE
DOUBLE ROLLER TIMING CHAIN / NEW WATER PUMP
TA 49 TURBO REBUILT BY PRECISION TURBO
3" DOWN PIPE WITH EXTERNAL TIAL WASTEGATE / MANUAL TURBO BOOST CONTROLLER BY TURBONETICS
PRECISION TURBO SAVER OIL FILTER RELOCATOR
BIG MOUTH AIR FILTER 4"/3" FROM MARK AT TR CUSTOMS
FRONT MOUNT INTERCOOLER FROM GN1 PERFOMANCE
DUAL RADIATOR FANS/WITH RMI-25 ADDTIVE
B&M TRANNY COOLER
10" 3000 LOCK UP CONVERTER
SMC ACHOHOL KIT FROM
60LB FUEL INJECTORS
TURBOTWEAK STREET CHIP 5.6v
ACCUFAB ADJUSTABLE FUEL REGULATOR / FUEL PRESSURE GAUGE
FUEL PUMP UPGRADE & FUEL PUMP HOT WIRE KIT
SCANMASTER 2.1
CASPERS V-PLUS VOLT BOOSTER
LS1 MAF SENSOR
MAF TRANSLATOR
HOOKER 2 1/2" DUAL EXHAUST
DUMP PIPE
EATON POSI REAR
EIBACH LOWERING SPRINGS
BILSTEIN SHOCKS ON ALL CONERS
DRAG AIRLIFT AIRBAGS LEFT&RIGHT
ALL LOWER BODY BUSHINGS FROM KIRBAN
REAR SEAT BRACE FROM KIRBAN
FRONT FRAME BRACE
ENGINE TORQUE STRAP
S10 REAR BRAKE CYLINDERS/ FRONT & REAR PADS
WELDS DRAGLITE RIMS 15" 15X8 REARS / 15X 7 FRONTS (ORGINAL STOCK GN RIMS INCLUDED)
TIRES BFGOODRICH T/A DRAG RADIALS 275/50 REAR FIRESTONES 215/65 FRONT
INTERIOR IS CLEAN WITH NO TEARS ON SEAT
BRUSHED ALUNIMUN OVERLAYS ON DASH, CONSEL&STEERING WHEEL FROM MARK AT TR CUSTOMS
TRANNY SHIFTS SMOOTH AND STRONG WITH NO ISSUED/WAS FLUSHED WITH NEW FLUIDS AND FILTER
A/C COLD
PAINT IS FAIR FOR ORGINAL PAINT MANY LITTLE DINGS AND SCRATCHES ,BUT PASSABLE NEED NEW PAINT FOR SHOW CAR
VDO BOOST,OIL,VACCUM & TEMP GAUGES
RUNS 21 PSI OF BOOST WITH NO KNOCK
IT WAS AT THE TRACK ONCE , 1/8TH MILE FOR TEST&TUNE DID MID 7 FOR A NEWBIE RACER
GO TO ---> YouTube - Jr's grandnational vs turbo t
NEED $14,000 FIRM I AM LOCATED IN TAMPA HGHOST@NETZERO.NET
NEW ENGINE
B&M TRANNY COOLER
60LB FUEL INJECTORS
SCANMASTER 2.1
LS1 MAF SENSOR
MAF TRANSLATOR
DUMP PIPE
EATON POSI REAR
FRONT FRAME BRACE
ENGINE TORQUE STRAP
A/C COLD
