87 Buick GN RACE Ready ROLLER
87TurboGN
I am selling my 87 Buick GN as a Roller. The link below will take you to pictures of the car. I can provide more specific pics upon request from serious buyers.
http://www.turbobuick.com/forums/tu...y/285266-my-new-109-build-wilson-asplund.html
87 Buick Grand National 9.81 Pass Clay City KY - YouTube
87 Buick GN New Motor 9 sec - YouTube
The Condition of the paint is good, but not perfect. It is Original, shines, but has chips and the normal wear. There is a rust spot in the door and one in the rocker, but nothing major. This has been stored in a garage by me for 5 or so years and 5 or so year by the previous owner. There is no damage to any panel and this car has had only 500 miles put on it since I bought it. It goes to the track and shows.
If you are looking for a racing chasis, this is what you need. This car is set up with the best parts. The list below are the parts that come with the car. Only needs a motor. I was easily able to footbrake 9.80 passes int he car with its set up. There are a lot of details and questions serious buyers will have and I am open to phone calls to discuss. 859-312-3184 CHRIS
Coolant Tank $35.00
AC Delete Plate with Rain Gutter $75.00
Drive Shaft Loop $75.00
SX Fuel Filter $80.00
Knock GAUGE $90.00
Line Lock - Brake System $100.00
LT1 Vacum Pump $103.00
Moroso Rear Mount Battery Case $125.00
SX Regulator $144.00
Manual Steering Box $150.00
Front Lowering Springs $150.00
Adjustable Drag Shocks $150.00
2 Fire Extinguishers $150.00
4 Autometer Gauges $151.00
Ultimate Diff Cover with Supports $155.00
Remote Oil System $155.00
Yokohama Front Tires $160.00
Tru Filter Oil filter $180.00
Moroso Aluminum Tranny Pan $245.00
Fuel Cell 15 Gal $250.00
Autometer Tach 6856 $270.00
Atomic Derale Fan Trans Cooler System $275.00
HR Adjustable Upper Control Arms $300.00
Carbon Fiber Trans Shiled $300.00
2 Rear Draglites $300.00
MSD Voltage Booster $305.00
2 Front Drag Lites Powder Coated Black $308.00
Jerry Bickel Cro-Moly Drive Shaft $325.00
Goodyear Drag Radials 70% $368.00
Custom Shifter $375.00
2 M/T Stiff Wall 10.5 Drag Rites with Tubes $375.00
2 Simpson Harness's $400.00
2 Convo Pro DRAGLITES $400.00
HR Lower Rear Control Arms - Derlin Bushings $407.00
Upgraded Spindles $425.00
GN Aluminum Performance Radiator $450.00
SX Fuel Pump $500.00
HR Sway Bar $550.00
Mosler Axles, Welded Spool $573.00
Roll Cage and Installation $624.00
Custom Turbo Converter $900.00
Extreme Automatics Stage 2 Turbo 400 Reverse Manual Vale Body -Trans Brake $2,000.00
Parts add up to $13,500.
I am asking $13,500 FIRM for the car with the parts above.
I have the complete 9 sec 109 setup that will be sold seperately, unless a deal can be struck. I also have a Mint Stage II 3.8 that is only .10 over. None of these parts will be sold until I move the Roller.
Clear Title
PM or Call me with Questions.
