HI all,
I have a 1987 GN for sale. Its had over 6500 spent on the running gear rebuild. Engine was rebuilt less than 5000 miles ago and transmission was rebuilt less than 1000 miles ago. Its had many add ons/bolts on put on it such as:
Aluminum Drive shaft
Small Pulley
Voltage Booster
Remote Fan switch on the dash
Remote Trunk Opener
Column Lock(Steadfast)
Rear/Front Frame Braces
Torque Strap
Hi Volume Oil Pump
Turbo Guard Oiler
Battery in Trunk
Metal Tinted Windows
Large K & N Filter
Ram Air Intake
Solid MAF Pipe
Larger Core Radiator
Duttweiller Oversized Neck
Transmission Cooler
2800 Stall Convertor
Bilstein Shocks
VDO Boost, Oil, Water
145 MPH Speedometer
Casper Electronics dial a chip
Knock Sensor
TPS Tec
Center Arm Cushion
Plenum Spacer
Ground Wire Kit
2 1/2 Cat Back Exhaust with Resonators
Adjustable Fuel Pressure Regulator
Hi Torque Starter
Remote Solenoid
Upper/Lower Urethane Bushings
Rear Airbag suspension
I have a new headliner I am letting go with the car along with other miscellaneous parts.
Body is in pretty good shape, paint is faded as to be expected and has a few dents and dings. I originally bought it to finish the restoration but now don't have the time or the money I'd like to put into it. I am asking $8500 OBO for it. For more info and pictures email me at
RLinnenkoh@Aol.com
Thanks,
Rex
__________________
One Fast 87
Small Pulley
Voltage Booster
Remote Trunk Opener
Torque Strap
Hi Volume Oil Pump
Turbo Guard Oiler
Battery in Trunk
Large K & N Filter
Ram Air Intake
Solid MAF Pipe
Transmission Cooler
Bilstein Shocks
145 MPH Speedometer
Knock Sensor
TPS Tec
Center Arm Cushion
Plenum Spacer
Ground Wire Kit
Hi Torque Starter
Remote Solenoid
RLinnenkoh@Aol.com
Thanks,
Rex
__________________
One Fast 87
