The car currently has 36,400 miles on the odometer. I am fifth owner according to clean carfax. PW, PL, cold AC, trunk release. The car drives like new and very solid even with T-tops. New poly bushings on front upper control arms. No leaks or noise from T-tops. Everything works except radio went dead 2 weeks ago. Paint is very good (although not perferct) with incredible depth as you can see from pictures. Last week was first time on dyno with 382 rwhp / 492 rwt. Asking price $17,900. call Tony at 586 255-8259.
Engine
· Rebuilt engine at 32,500 miles (have receipts)
· .41 over bored and balanced
· Ported iron stock heads
· Ported intake
· RJC power plate
· RJC Bullet Proof Head Gaskets
· Cam 10/10 grind
· T&D Roller rockers
· 50lb Precision injectors
· 62 mm throttle body
· 60 mm Precision turbo
· Heated 4-wire oxygen sensor
· Tinman cold air kit
· Headers
· Duttweiler neck on stock intercooler
· Hot wired fuel pump - Turbonetics
· 3” Stainless Steel downpipe with 38mm external wastegate (GN1)
· 3” Stainless Steel catback exhaust and test pipe (GN1)
· Adjustable boost controller
· Progressive Alky injection system
· Performance chip
· Scanmaster 2.1
· New battery (purchased 7/08)
Suspension
· Tubular upper and lower rear control arms (UMI)
· Rear air bags
· Front frame, underhood and connecting braces
· Slotted and drilled front rotors
· Vacuum brake conversion
· Larger rear drum brakes
New fornt upper control arm poly bushings and front-end alignment
Transmission
· Upgraded 200r4 (bullet proof) (have receipts)
· B&M Ratchet Shifter
· Modified Art Carr cast aluminum pan
· Trans cooler
· 3.42 posi rear end
Interior
· GNX style dash
· New steering wheel
· All plastic perfect except small crack in front driver side speaker grill
· Seats are very good to excellent
· GNX style headrests
· Overall interior 9 out of 10
· Knock gauge
· Power windows, locks, truck release
· Concert sound
Exterior
· GNX louvers and wheel flairs
· Body is rust free with the exception of front lower doors that have minor bubbles
· Weld pro-star wheels in perfect condition
· Tires front 215/65/15 rear 275/60/15
· T-Tops and weather-stripping very good no leaks
Engine
· Ported intake
· RJC power plate
· Cam 10/10 grind
· Headers
· Performance chip
· Scanmaster 2.1
Suspension
· Rear air bags
Transmission
· Trans cooler
Interior
· GNX style dash
· Knock gauge
· Concert sound
Exterior
